Step file/CAD Data of DWM3001CDK
I need to design a housing for the DWM3001CDK for a university project. Is it possible to get the step files?
I make no guarantees at all about its accuracy, but I just finished cad’ing it up to make my own enclosure. I had to upload it to my blog because you can’t upload .step files here apparently. http://housedillon.com/files/Qorvo%20DWM3001CDK_C2%20v1.step
Thank you very much - that will help!
The buttons are not quite perfect, and the USB ports are about .2 mm off as well. But, I was able to make an enclosure that worked with this model.
Hi, i cannot acces the link : http://housedillon.com/files/Qorvo%20DWM3001CDK_C2%20v1.step
I am also a student and need a housing for the board. Would be extremily grateful if you could send me the file.
Hi @NiHorvat ,
You can also look at this design if you are cannot get it from @hpux735
Thank you, but what i am looking for is the board 3D model so that i can design my own stand/enclosure.
I think you can modify the URL to https://housedillon.com/files/Qorvo%20DWM3001CDK_C2%20v1.step add the s to http as most browsers block http
Hello, would you have a STEP file that includes the J7, J10, and J19 connectors as well? Thank you.
