Hi
I want to increase the Signal Power of MDEK1001 to increase positioning distance.
I have read this discussion below, but that was two years ago,
Can we adjust the signal power for the current version now?
Thanks !
Zac
Hi
Thanks !
Zac
Hi
TX signal power can be adjusted using the utps command in PANS (see section 6.22 in the DWM1001 firmware API guide) or the Transmit Power Control register, address 0x1E in your own firmware (see section 7.2.31 in the DW1000 user manual).
Note that by doing so you might violate regulation in terms of radio emissions / emission mask. This depends on e.g any casing used in your product.
