DWM3001CDK Initial Setup
I have purchased 5 DWM3001CDK boards for my initial UWB testing with 3 anchors and 2 tags.
I was going through the DWM3001CDK quick setup guide, which mentions using of QM33120WDK and GUI for setup.
Do I need QM33120WDK? These are very expensive.
Hi Hgoomer,
What you can achieve depends on your goals. The DWM3001CDK boards provide distance information between two devices, while the QM33120WDK offers both distance and angle measurements.
If you’re referring to the Qorvo One TWR app as the GUI, you can use it with the DWM3001CDK, but angle information won’t be available—that’s only supported by the QM33120WDK.
With the DWM3001CDK alone, it’s best to run one-to-many TWR ranging sessions to get distance data from one initiator to multiple responders.
To get started, check out this tutorial:: Tutorial: How to Use DW3 QM33 SDK for One to Many FiRa Ranging.
best regards,
-Quan
