I am new here and I just received the development kit.
I am trying to build a device that can have UWB and use BLE to send data. I have some experience coding nrf52832 but I am new to UWB. I wonder what I should start with. By looking into the documents, I found two example projects, the example on github:GitHub - Decawave/dwm1001-examples: Simple C examples for Decawave DWM1001 hardware, and the DWM_1001_on_board_package which is mentioned in the API Firmware User Manual.
What are the differences between these two projects? What do you recommend me to look into first?
Hi @xx11
the github repositories are bare code examples. The “API Firmware User Manual” is for PANS firmware which is all in one RTLS (closed source) solution .
Thanks for your reply. If I want to build my own firmware to run on the DWM1001C, which example do you recommend me to start with? The twr example or the dwm_simple, or any other examples?
