Additional Symbols
I think it’s, unfortunately, hardwired to Microsoft’s Tahoma (something configurable like Bahnschrift would have been nice).
@mgyger: Thank you for your work, this is great!
Just wondering: is there a configuration to let the standard shortkeys (D,Q,…) point to the a symbol of choise?
Please see this topic:
I don’t think its possible (yet).
But if there was an option to re-point the shortkeys (not yet possible it seems) then the built-in symbols would not need to be modified I expect.
@mgyger Did the schematic in your .pdf actually simulate? Or was it for documentation only? Can we use the elektuur “flat line” ground symbol instead of the Qspice triangle symbol and still netlist it as the 0 node?
That one actually doesn’t work (as well as the test points). I added it so it can be put on top of one of the regular ground symbols and that one can then be removed manually from the PDF, if desired.
The 2 simulation files are available here: https://gitlab.com/mgyger/qspice-symbols
Please explain how to find these symbols, I have searched for 21 on groups.io but find nothing. Thank you
