Good morning
I wanted to create a thread to share my experience with Model Generator and compare it with others.
I’ve used MOSFET generator to create a model
Preliminaries:
First thing I’ve noticed was that ctrl+v (paste) shortcut doesn’t work here, however mouse leftclick+paste does. Stangely ctrl+x (cut) does work.
Second thing - I think it would be more intuitive to put some kind of border (a thick line for example) between section that is purely informational and one that has actual impact on model behaviour. I know this information is visible in Help Docs, but still.
The digitize feature:
The digitizer feature is very usefull and easy to use (once accustomed). Remember to configure the plot first (set limits, logarythmic axes) BEFORE selecting any particular points from the datasheet plot. Already selected points won’t recalculate automatically if you change plot settings.
The thing I feel like is missing here is more direct marking of the points (placing a marker - just like in simulation waveform plot - picture attached)
and ability to manually enter the values instead of using digitizer (or to currect values acquired via digitizer).
Also I was getting some kind of redering errors throughout the process (which would appear randomly) and could be fixed by switching between tabs (picture attached - don’t mind the red annotations)
What do You think ?
