Hi Qorvo Team,
What’s the difference between DW3000 and DW3700??
Hi Qorvo Team,
Hi @KOv01 ,
As said in this thread What is DW3700???, please consider QM33 instead of DW3700.
For differences between DW3000 and QM33, I’ve replied in this thread What is the difference between DW3120 and QM33120W?
That message refers to https://www.decawave.com/wp-content/uploads/2022/03/DW3xxx_XR6.0C_24Feb2022.zip which is a dead link.
Could you please either update that thread or this one with a working link to the latest source code that supports the QM33
Hi @AndyA
Please check this link for release XR6.0C
https://drive.google.com/drive/u/0/folders/1s473vVhpg2bd-4L6pDNsKIH-RWb1mLFy
please note that this is unofficial release. This will be deleted once Qorvo finishes their website migration.
The DW3000 is a double bass peddle with top quality construction material that can take a beating and still be able to give you a good feel both on your feet and when the beater strikes the head of your bass drum. It has turbo drives that are dual chain and with a sprocket design. This allows you to have better timing and a more realistic feel because you will have a better connection between the footboard and the sprocket.
For the DW3700, I don’t think it’s on the market.
