I made a single element library, which contains a symbol and the related “implementation” schematic. Its purpose to use them in different projects (i.e. on a different QSPICE schematic). I put the two file in a directory and added the direcory to QSPICE (Symbol Browser / Add Symbol Directory).
I tried run the simulation and it failed. The schematic which was referenced by the symbol, was not found. I put this referenced schematic into the directory where is the qsch is, it started working. Do I understand correctly that the symbol’s implementation schematic should be in the direcory where I use the symbol? Should I copy the whole library implementation into every usage direcory? Or do I miss or mess up something?
I was very happy when I saw the Symbol and IP Browser and there is an explicit way to “link” direcory
to the QSPICE, but the real linking/referencing not needs to copy the files in every use-place.
