Wave viewer closing suddenly and in need of being reopened-----annoying
since my last update, i got the phenomenon of “wave viewer” window closing abruptly while simulation is busy". Has anyone experienced the same problem? It happens continuously for every simulation.Thanks
I recently had this problem. I wrote about it a little earlier.
it happens when you try to modify the wave viewer while simulation is still busy. When the results are available, it does not shut down anymore.
I can replicate this problem with @bordodynov schematic “irfp150n.qsch” which he upload in other post. Do you encounter this problem with a particular schematic?
Noticed this today: 07/02/2024 Trapped a crash mode in the waveform viewer.
Maybe solved?
–robert
@bordodynov example was sent to Mike for review and with this fix, if @alastas no longer experience such problem following the update, the issue is likely fully resolved.
Thanks I will try later on my personal PC because it’s there that I have problems. At the office, it’s still an old version of QSPICE, so the wave view problem did not happen there.
