Hi Mike,
I’m having a lot of fun with Qspice. Thanks for the great work.
I’d like to integrate the verilog build into a visual studio build. Can you provide the command line(s) that you use to run verilator and then build the dll?
Dale
Hi Mike,
Dale
Managed to figure this out for myself, I think…
I was able to take the VerilogCounter.qsch and rebuild just using the counter.v file and ms visual studio…
First (one-time) step is to rebuild the verilated.lib file - msvs doesn’t like the dmc version. You can find the verliated.cpp file to build it from in the QSPICE/dm/verilator folder. You will need to add the text “extern” at the beginning of line 277 of verilated.h to get it to build in msvs:
extern int (*DLLprintf)(const char *fmt, …);
You probably want to keep this new verilated.lib separate from your QSPICE install so that it doesn’t interfere with DMC functionality and doesn’t get overwritten with updates.
Create a DLL project called “counter” in msvs and copy VerilogCounter.qsch and counter.v into the folder.
Open VerilogCounter.qsch
To generate the counter.cpp “DLL Main” file then right click on schematic symbol > Verilog Interface > Create C** .DLL Main Template.
The verilator command generates the other Vcounter*.cpp files:
Verilator.exe --cc -Wno-LITENDIAN counter.v
You can add this as a pre-build step in msvs with a suitable path to your QSPICE/dm/verilator folder inserted before Verilator.exe.
Project Properties>Build Events>Pre Build Event
Add your new msvs version of verilated.lib as input:
Project properties>Linker>Input>Additional dependencies
Set the project configuration to “Release” and “x86” using msvs toolbar.
Change the Output directory to the same as all the other files:
Project Properties>(check that Release and Win32 are selected)>General>Output Directory>$(SolutionDir)
Build the project and you should get counter.dll in the same folder as VerilogCounter.qsch.
You should now be able to run the sim - from the Qspice UI press the green run button in the menu.
