VCTRL pin voltage of QM14068
I’m trying to connect the EXTRXE pin of DW3120 to the VCTRL of qm14068, but the VDD of DW3120 is 3.0V.
The VCTRL of QM14068 needs to be controlled to 1.8V, but is there a big problem in terms of control timing if I use a level shifter in the middle?
Or, is there a recommended connection method?
There is an Application Note for using QM14068 with the DW3000 family: APS304 . You can see this under the “Documents” tab on the product page: https://www.qorvo.com/products/p/QM14068#documents
