Does Qspice have VCCS with limiter shown as in Simetrix?
We can utilize the ‘Behavioral source’ as a VCCS with a current limiting function.
Oh, it appears that the syntax ‘Gxxx n+ n- value={}’ has been removed in QSPICE.
Correction!
I realize there was a misunderstanding. It actually works fine!
With suggestion from @EL34 , I created two VCCS_Ilimit symbol which you can test with. I use limit(x,y,z) function, which equivalent to max(min()) function. But I only make symbol equivalent to “ideal damping” as described in Simetrix.
You can download these two symbols from this Github link
Qspice/Symbols at main · KSKelvin-Github/Qspice
If you cannot recreate your simulation results as in Simetrix, please post your setting and simulation results for verification.
Thanks, It worked
There is another model in QSPICE which is OTA can be used as well for my application
