UWB to connect several devices in parallel while sharing the same RF channel?
I’m searching for a way to link several devices simultaneously using a fixed UWB RF channel for UWB data connection.
I was employed by Bluetooth, which operates between 2.4 and 2.48GHz (80MHz to 40 channels, each 2MHz) and allows for the interference-free connection of many devices every 2MHz.
Is there any alternative concept in DW1000 similar to BLE? I discovered a sub-banding technique online. Can I use Sub-Banding with DW1000 or DW3000 modules?
Thanks in advance
