we want to use LPC824 ARM cortex M0 ((30Mhz, 32 bit, 32kB flash) with the DWM1000 module. Is this micro available to indoor asset tracking application?
Thank you,
Thank you,
Hi Feramuz,
It is possible to use DWM1000 with the [color=#333333][size=small]LPC824 ARM cortex. What you’ll need to do is to setup a SPI communication between your mcu and the DW1000.[/size][/color]
[color=#333333][size=small]Then you’ll be able to control the DW1000 from the LPC824 using the API that you can find there : https://www.decawave.com/software-download.[/size][/color]
[color=#333333][size=small]Let us know how the porting goes ![/size][/color]
[color=#333333][size=small]Yves[/size][/color]
[color=#333333][size=small] [/size][/color]
Hi Yves,
thank you for your information. I will inform you asap.
feramuz
