Hi all, I am working on a project which requires the use of dwm1001-dev module to create a LED lighting system. The aim is to program and integrate the dwm1001-dev module with an LED and relay so that I can control the LED on and off using nRF toolbox application on my mobile device. Issues I am facing:
- unable to find any codes online that can program dwm1001-dev module as a LED controller
- not sure which component on the dwm1001-dev module should be connected to the LED and relay
Is anyone able to help with this? Thank you so much in advance.
