Is it possible to use DecaRangeRTLS PC application with three EVB1000 (from Trek1000 kit) configured as anchors and DWM1001-DEV (with default fw) as a tag that will appear in the application?
If not, what needs to be done (fw/sw/Trek1000 jumper config) to enable this?
[color=#333333][size=small]DWM1001-DEV and [/size][/color] [color=#333333][size=small]Trek1000 kit [/size][/color]are using different firmware and hardware except the DW1000 module.
One possible solution is to port the firmware of [color=#333333][size=small]Trek1000 to[/size][/color] [color=#333333][size=small]DWM1001-DEV.[/size][/color]
