Can we use the IMU on dwm1002(node)? I can only enable the dwm1003(tag)'s IMU with PC GUI.
Thanks for any advice.
Yes you can, please write your own code to support the IMU sensor on the PDoA Node.
Thanks for your reply. I found the IMU driver code in PDOA-KIT’s official file, but I don’t know how to use it. Are there any uart command to enable the IMU on dwm1002?
Take a look at how the functionality of the IMU is implemented on the tag. You could probably get the IMU to work on the node in a similar manner.
