hello,
It might be a silly question, but I’m not very familiar with UWB systems, and I’d like to know if it’s possible to use the DWM3001C without another PCB, in order to minimize the size of the module. If I understand correctly, it’s necessary to use the DWM3001CDK as an anchor, but is it possible to use the DWM3001C as a tag?
The DWM3001C can be used as an anchor or tag but the module itself does need to be placed on a PCB. For example, you need to supply it power.
hello,
thanks for your answer.
i wanted to know what is the bare minimum for the tag to work. is it only necessary to power it?
because i want to make a bracelet with this module the dwm3001C and i would like to save as much space as possible.
@flochoco , the module has an integrated MCU but you need to program it so you will need to make the SWD lines accessible to do so. Perhaps, you might want to send some data from this MCU to another processor in your system or you might want to have some LEDs to indicate operation or some events that could occur.
