I am looking to get started with the QPF5010EVB as per the datasheet biasing instructions.
- Can you provide me the application note or getting started guide to bias this board. Planning to use standard power supplies, switches and current limiting?
- Secondly I am planning to connect it to a low cost GaN driver circuit. Please suggest a low cost module and application circuit for the same.
- Planning to operate short duration (50usec to 200usec) CW inputs. What is the Tx Psat in this case? The 40dBm value or 14dBm.
