I’m evaluating the QPA2962 and would appreciate guidance on its thermal characteristics. Is the device suitable for topside cooling, and are the datasheet θJC values worst-case values? For pulsed operation, how should I use the GaN application note to estimate θJC and junction temperature? Should I use peak or average power, and can Qorvo model a specific operating case?
I’m also trying to understand the datasheet’s 191 °C temperature figure and how it relates to the reliability curves and higher junction temperatures.
Posted by FAE: The following thread summarizes a real customer application-support discussion. The content has been reformatted into a forum-style Q&A to make the information easier to search and reference by the engineering community.
The QPA2962 is not designed for topside cooling. Its thermal paths are optimized and characterized for cooling through the ground paddle; because it is an air-cavity package, topside cooling would not provide appreciable benefit. The datasheet θJC values are conservative typical values, not statistically established maximums.
For a modulated, non-pulsed waveform, use average power for thermal calculations. For pulsed operation, use peak power as the baseline. For pulse widths over 1 ms, use the peak power and thermal resistances in the Thermal and Reliability table. For shorter pulses, use the application note to account for the lower peak junction temperature relative to CW operation. A full thermal simulation is available for a specific use case.
The application note applies to Qorvo GaN devices, but its pulsed thermal-resistance values do not directly apply to the QPA2962. They can be used to estimate the ratio of pulsed to CW thermal resistance for a given pulse width, duty cycle, junction temperature, and peak-power condition.
For example, the 10% duty-cycle, 100 µs value is 1.45/2.08 = 69.7% of the CW value. Applied to the QPA2962’s 2.82 °C/W value, that estimates about 1.97 °C/W.
For a 1 µs pulse at 20% duty cycle, the app-note example chart-based temperature rises at 44.7 W peak dissipated power are:
These are first-order estimates. GaN and SiC thermal resistance increase with temperature, and 85 °C is the maximum operating case temperature. A full thermal model is recommended for greater accuracy. The QPA2962 average weight was also reported as 80.62712 mg.
