I’m attempting to use several ESP32 UWB DW3000 to create a 3D positioning system in real-time for multiple users. Currently, I have the 3D positioning code running as well as code to display the output. The only issue remaining is getting multiple tags running. Given the interference issues of running two tags simultaneously, I need to have a way to notice each tag of its turn in the order.
To accomplish this, I am trying to have each tag set to a receiving mode for its unique ID and one of the tags in its transmitting mode for the unique ID of the receiver. I have anchors spread across the room that have the receiving mode working, but when I try to integrate that into the tags, it fails to function properly as the receiver never gets the correct message. I was hoping someone here had an idea of where the issue lies.
The transmitter and receiver functions were essentially ripped right from the simple ranging example provided by Makerfabs in their github page here.
Let me know if y’all have any questions.
If you have any comments about how to clean up the code, that would be appreciate too.
The following code is for the TAG:
#include <dw3000.h>
#include <ArduinoJson.h>
#include <WiFiUdp.h>
#include
#include <math.h>
#include <WiFi.h>
#include
#include <SPI.h>
extern SPISettings _fastSPI;
// Vector Variables
std::vector<std::pair<int, std::vector>> keys;
std::vector clock_offset;
std::vector averages;
// General Variables
int tag_id = 2;
int num_tags = 4;
double tof;
bool start = true;
************ GEN CONFIG OPTIONS ************
// connection pins
const uint8_t PIN_RST = 27; // reset pin
const uint8_t PIN_IRQ = 34; // irq pin
const uint8_t PIN_SS = 4; // spi select pin
#define TX_ANT_DLY 16385
#define RX_ANT_DLY 16385
#define ALL_MSG_COMMON_LEN 10
#define ALL_MSG_SN_IDX 2
#define RESP_MSG_POLL_RX_TS_IDX 10
#define RESP_MSG_RESP_TX_TS_IDX 14
#define RESP_MSG_TS_LEN 4
#define POLL_TX_TO_RESP_RX_DLY_UUS 240
#define RESP_RX_TIMEOUT_UUS 400
#define POLL_RX_TO_RESP_TX_DLY_UUS 450
/* Default communication configuration. We use default non-STS DW mode. /
5, / Channel number. /
DWT_PLEN_128, / Preamble length. Used in TX only. /
DWT_PAC8, / Preamble acquisition chunk size. Used in RX only. /
9, / TX preamble code. Used in TX only. /
9, / RX preamble code. Used in RX only. /
1, / 0 to use standard 8 symbol SFD, 1 to use non-standard 8 symbol, 2 for non-standard 16 symbol SFD and 3 for 4z 8 symbol SDF type /
DWT_BR_6M8, / Data rate. /
DWT_PHRRATE_STD, / PHY header rate. /
(129 + 8 - 8), / SFD timeout (preamble length + 1 + SFD length - PAC size). Used in RX only. /
DWT_STS_MODE_OFF, / STS disabled /
DWT_STS_LEN_64,/ STS length see allowed values in Enum dwt_sts_lengths_e /
DWT_PDOA_M0 / PDOA mode off */
static uint32_t status_reg = 0;
static uint64_t poll_rx_ts;
static uint64_t resp_tx_ts;
extern dwt_txconfig_t txconfig_options;
************ TWR TRANSMISTTER MODE ************
void twr_transmitter_mode(int key, double& tof)
uint8_t frame_seq_nb = 0;
uint8_t rx_buffer[20];
uint8_t tx_poll_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, ‘W’, ‘A’, (uint8_t) key, ‘E’, 0xE0, 0, 0};
uint8_t rx_resp_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, (uint8_t) key, ‘E’, ‘W’, ‘A’, 0xE1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
/* Write frame data to DW IC and prepare transmission. See NOTE 7 below. /
tx_poll_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_TXFRS_BIT_MASK);
dwt_writetxdata(sizeof(tx_poll_msg), tx_poll_msg, 0); / Zero offset in TX buffer. /
dwt_writetxfctrl(sizeof(tx_poll_msg), 0, 1); / Zero offset in TX buffer, ranging. */
/* Start transmission, indicating that a response is expected so that reception is enabled automatically after the frame is sent and the delay
- set by dwt_setrxaftertxdelay() has elapsed. */
dwt_starttx(DWT_START_TX_IMMEDIATE | DWT_RESPONSE_EXPECTED);
/* We assume that the transmission is achieved correctly, poll for reception of a frame or error/timeout. See NOTE 8 below. */
while (!((status_reg = dwt_read32bitreg(SYS_STATUS_ID)) & (SYS_STATUS_RXFCG_BIT_MASK | SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR)))
/* Increment frame sequence number after transmission of the poll message (modulo 256). */
frame_seq_nb++;
if (status_reg & SYS_STATUS_RXFCG_BIT_MASK)
uint32_t frame_len;
/* Clear good RX frame event in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_RXFCG_BIT_MASK);
/* A frame has been received, read it into the local buffer. */
frame_len = dwt_read32bitreg(RX_FINFO_ID) & RXFLEN_MASK;
if (frame_len <= sizeof(rx_buffer))
dwt_readrxdata(rx_buffer, frame_len, 0);
/* Check that the frame is the expected response from the companion "SS TWR responder" example.
* As the sequence number field of the frame is not relevant, it is cleared to simplify the validation of the frame. */
rx_buffer[ALL_MSG_SN_IDX] = 0;
if (memcmp(rx_buffer, rx_resp_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t poll_tx_ts, resp_rx_ts, poll_rx_ts, resp_tx_ts;
int32_t rtd_init, rtd_resp;
float clockOffsetRatio;
/* Retrieve poll transmission and response reception timestamps. See NOTE 9 below. */
poll_tx_ts = dwt_readtxtimestamplo32();
resp_rx_ts = dwt_readrxtimestamplo32();
/* Read carrier integrator value and calculate clock offset ratio. See NOTE 11 below. */
clockOffsetRatio = ((float)dwt_readclockoffset()) / (uint32_t)(1 << 26);
/* Get timestamps embedded in response message. */
resp_msg_get_ts(&rx_buffer[RESP_MSG_POLL_RX_TS_IDX], &poll_rx_ts);
resp_msg_get_ts(&rx_buffer[RESP_MSG_RESP_TX_TS_IDX], &resp_tx_ts);
/* Compute time of flight and distance, using clock offset ratio to correct for differing local and remote clock rates */
rtd_init = resp_rx_ts - poll_tx_ts;
rtd_resp = resp_tx_ts - poll_rx_ts;
tof = ((rtd_init - rtd_resp * (1 - clockOffsetRatio)) / 2.0) * DWT_TIME_UNITS;
else
/* Clear RX error/timeout events in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_ALL_RX_TO | SYS_STATUS_ALL_RX_ERR);
/* Execute a delay between ranging exchanges. */
delayMicroseconds(750);
************ TWR RECEIVER MODE ************
void twr_receiver_mode(int key)
uint8_t rx_poll_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, ‘W’, ‘A’, (uint8_t) key, ‘E’, 0xE0, 0, 0};
uint8_t tx_resp_msg[] = {0x41, 0x88, 0, 0xCA, 0xDE, (uint8_t) key, ‘E’, ‘W’, ‘A’, 0xE1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
/* Activate reception immediately. */
/* Poll for reception of a frame or error/timeout. See NOTE 6 below. */
while (!((status_reg = dwt_read32bitreg(SYS_STATUS_ID)) & (SYS_STATUS_RXFCG_BIT_MASK | SYS_STATUS_ALL_RX_ERR)))
uint32_t frame_len;
/* Check that the frame is a poll sent by "SS TWR initiator" example.
if (memcmp(rx_buffer, rx_poll_msg, ALL_MSG_COMMON_LEN) == 0)
uint32_t resp_tx_time;
int ret;
/* Retrieve poll reception timestamp. */
poll_rx_ts = get_rx_timestamp_u64();
/* Compute response message transmission time. See NOTE 7 below. */
resp_tx_time = (poll_rx_ts + (POLL_RX_TO_RESP_TX_DLY_UUS * UUS_TO_DWT_TIME)) >> 8;
dwt_setdelayedtrxtime(resp_tx_time);
/* Response TX timestamp is the transmission time we programmed plus the antenna delay. */
resp_tx_ts = (((uint64_t)(resp_tx_time & 0xFFFFFFFEUL)) << 8) + TX_ANT_DLY;
/* Write all timestamps in the final message. See NOTE 8 below. */
resp_msg_set_ts(&tx_resp_msg[RESP_MSG_POLL_RX_TS_IDX], poll_rx_ts);
resp_msg_set_ts(&tx_resp_msg[RESP_MSG_RESP_TX_TS_IDX], resp_tx_ts);
/* Write and send the response message. See NOTE 9 below. */
tx_resp_msg[ALL_MSG_SN_IDX] = frame_seq_nb;
dwt_writetxdata(sizeof(tx_resp_msg), tx_resp_msg, 0); /* Zero offset in TX buffer. */
dwt_writetxfctrl(sizeof(tx_resp_msg), 0, 1); /* Zero offset in TX buffer, ranging. */
ret = dwt_starttx(DWT_START_TX_DELAYED);
/* If dwt_starttx() returns an error, abandon this ranging exchange and proceed to the next one. See NOTE 10 below. */
if (ret == DWT_SUCCESS)
/* Poll DW IC until TX frame sent event set. See NOTE 6 below. */
while (!(dwt_read32bitreg(SYS_STATUS_ID) & SYS_STATUS_TXFRS_BIT_MASK))
/* Clear TXFRS event. */
frame_seq_nb++;
else
/* Clear RX error events in the DW IC status register. */
dwt_write32bitreg(SYS_STATUS_ID, SYS_STATUS_ALL_RX_ERR);
************ PROGRAM SETUP ************
void setup()
Serial.begin(115200);
// WiFi Connection
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(1000);
Serial.println("Connecting to Wifi… ");
Serial.println(“Wifi connected”);
delay(2000);
UART_init();
_fastSPI = SPISettings(16000000L, MSBFIRST, SPI_MODE0);
spiBegin(PIN_IRQ, PIN_RST);
spiSelect(PIN_SS);
delay(2); // Time needed for DW3000 to start up (transition from INIT_RC to IDLE_RC, or could wait for SPIRDY event)
while (!dwt_checkidlerc()) // Need to make sure DW IC is in IDLE_RC before proceeding
UART_puts(“IDLE FAILED\r\n”);
while (1)
if (dwt_initialise(DWT_DW_INIT) == DWT_ERROR)
UART_puts(“INIT FAILED\r\n”);
while (1)
// Enabling LEDs here for debug so that for each TX the D1 LED will flash on DW3000 red eval-shield boards.
dwt_setleds(DWT_LEDS_ENABLE | DWT_LEDS_INIT_BLINK);
/* Configure DW IC. See NOTE 6 below. */
if (dwt_configure(&config)) // if the dwt_configure returns DWT_ERROR either the PLL or RX calibration has failed the host should reset the device
UART_puts(“CONFIG FAILED\r\n”);
while (1)
/* Configure the TX spectrum parameters (power, PG delay and PG count) */
dwt_configuretxrf(&txconfig_options);
/* Apply default antenna delay value. See NOTE 2 below. */
dwt_setrxantennadelay(RX_ANT_DLY);
dwt_settxantennadelay(TX_ANT_DLY);
/* Set expected response’s delay and timeout. See NOTE 1 and 5 below.
- As this example only handles one incoming frame with always the same delay and timeout, those values can be set here once for all. */
dwt_setrxaftertxdelay(POLL_TX_TO_RESP_RX_DLY_UUS);
dwt_setrxtimeout(RESP_RX_TIMEOUT_UUS);
/* Next can enable TX/RX states output on GPIOs 5 and 6 to help debug, and also TX/RX LEDs
- Note, in real low power applications the LEDs should not be used. */
dwt_setlnapamode(DWT_LNA_ENABLE | DWT_PA_ENABLE);
for (int i = 0; i < 12; ++i) {
keys.push_back(std::make_pair(i, std::vector()));
************ PROGRAM LOOP ************
void loop()
if (!start || tag_id != 1) {
int new_id = tag_id + 12
twr_receiver_mode(new_id);
} else {
start = false;
advancedRanging(); ← 3D positioning function, unrelated to main issue
double distance = 0;
while (distance < 0.001)
twr_transmitter_mode(((tag_id % num_tags) + 1 + 12), tof);
