TQP7M9106 S-parameter Modelling Issue
I would like to use TQP7M9106 in my project for 2W, 500-1000 MHz amplifier.
Firstly I checked datasheet schematic (TQP7M9106-PCB900) for 920-960 MHz and have a issues with results.
We think s-parameter file for TQP7M9106 is not correct. We check using both uSimmics 5.8 (with ideal components) and AWR Design Environment V15. (with s-parameters components)
TQP7M9106 S-parameters from TQP7M9106 - Qorvo
Result below.
  1. uSimmics
  2. AWR Design Environment V15
Both modelling results are very similar and not expected.
Probably TQP7M9106-PCB900 schematic\BOM is not correct or TQP7M9106 s-parameters is not correct.
I would be gratefull for any comments, ideas and recommendation.
– Kind Regars,
Victor
The TQP7M9106 datasheet provides a list of critical component placement locations for this tune on page 4:
  • Center of C8 to TQP7M9106 (U1) device package is 243 mil (11.7º at 940MHz)
  • Center of L5 to TQP7M9106 (U1) device package is 452 mil (21.8º at 940MHz)
  • Center of C9 to TQP7M9106 (U1) device package is 275 mil (13.3º at 940MHz)
  • Center of C2 to TQP7M9106 (U1) device package is 355 mil (17.2º at 940MHz)
    These should be included in your simulations. There is a reference design for 450-800MHz, see attached.
    TQP7M9106 450-800 Refrence Design Appnote.pdf (252.5 KB)
Thank you, MJT.
Are there other TQP7M9106 Ref. Designs or Application Notes not listed on the product page?
Other available designs are 700-1000MHz, 700-800MHz and 700-900MHz
Where can I find them? Is there a link?
Uploaded here:
TQP7M9106 700-1000MHz Reference Design.pdf (211.0 KB)
TQP7M9106 700-800 Refrence Design Appnote.pdf (257.6 KB)
TQP7M9106_700_900MHz_ReferenceDesign.pdf (587.8 KB)
Hello, MJT
Thank you for support!
