- The S parameter files given for TQL9092 isn’t depicting the values of S11 and S22 as given in the data sheet. The S parameter file column 2 and 8 have values for S11magnitude and S22magnitude close to 0 but not negative as in the datasheet.
Could you please check the S parameter files uploaded and provide the correct files?
- What is the difference between the 2 S parameter files provided - TQL9092_deembedded_Sparam_with_NoiseParam.s2p and TQL9092_de-embedded_sparameters_3p3Vdd.s2p ?
