calculate is:
0.12821 [us]x((330+48+78+48)/2)+1.02564[us]x19/2+128x0.99359[us]+8x1/6.8 [us]=170.4us
0.12821 is the data symbol time in MAC. this value is multiplicate by MAC bits, but first Reed Solomon encoding adds the parity bit (48 bits per 330 bits, and 1 MAC frame consists of 408 bits if the payload is 12 byte) and the BPM/BPSK is due 2 bit per data symbol so I divide the bits by two.
1.02564 [us] is the PHR symbol time. The PHR is 19 bits, no Reed Solomon encoding but BPM/BPSK is working (divide by 2).
0.99359[us] is the preamble symbol duration. it comes 128,
tmp = msg->msg_len;
datalen_ns = tmp8.0 + 48.0ceilf(tmp*8.0/330.0);//number of bits + 48bits for each Reed-Solomon block (330bits or less)
// pre-calculated : PHR length is 172308ns for 110k and 21539ns for 850k/6.81M
// Refer to “Frame Format” of DW1000-Datasheet.pdf
switch (msg->dataRate)
case(DWT_BR_850K) :
datalen_ns = 1025.64f; //length of data message in ns for data
phrlen_ns = (211025.64); //PHR header 850K 21bit1025.64= 21539ns
break;
case(DWT_BR_6M8) :
datalen_ns = 128.21f; //length of data message in ns for data
phrlen_ns = (211025.64); //PHR header 6.8M 21bit1025.64= 21539ns
break;
default :
assert_param(0);
break;
/* sfd and preamble are in symbols */
sfdlen = (msg->sfdType == DWT_SFD_DW_16) ? DWT_SFD_LEN16 : DWT_SFD_LEN8;
//number of Symbols in preamble sequence
switch (msg->txPreambLength)
case DWT_PLEN_4096 : preamblelen = 4096.0f; break;
case DWT_PLEN_2048 : preamblelen = 2048.0f; break;
case DWT_PLEN_1536 : preamblelen = 1536.0f; break;
case DWT_PLEN_1024 : preamblelen = 1024.0f; break;
case DWT_PLEN_512 : preamblelen = 512.0f; break;
case DWT_PLEN_256 : preamblelen = 256.0f; break;
case DWT_PLEN_128 : preamblelen = 128.0f; break;
case DWT_PLEN_64 : preamblelen = 64.0f; break;
default : assert_param(0); break;
msg_time->preamble_us = (uint32_t)(preamblelen); //length of Preamble + SFD
msg_time->sts_us = (uint32_t)(stslen); //length of STS
msg_time->phr_us = (uint32_t)(phrlen_ns/1000); //length of PHR
msg_time->data_us = (uint32_t)(datalen_ns/1000); //length of Data
msg_time->phrAndData_us = (uint32_t)((datalen_ns+phrlen_ns) /1000);
msg_time->us = (uint32_t)(preamblelen + stslen + msg_time->phrAndData_us);//length of the whole frame
in the application Symbol time and Device time is used
Conversion of values to SYMBOL TIME: 1sy = 1.0256us
for wait4response timeouts you will need time in “Symbol” time:
tmp = (int)((preamblelen + msgdatalen) / 1.0256); //message length in “Symbol” time
Conversion of values to DEVICE TIME: 1dt = (uint64_t)((double)(1us/(double)DWT_TIME_UNITS)/1e6)
msg_time->sy = (uint32_t)util_us_to_sy(msg_time->us); //length of the whole frame in Symbol time units
msg_time->dt64 = util_us_to_dev_time(msg_time->us); //length of the whole frame in device time, uint64_t
msg_time->dt[0] = (uint8_t)(msg_time->dt64 &0xFF); //length of the whole frame in device TimeStamp
msg_time->dt[1] = (uint8_t)(msg_time->dt64>>8 &0xFF);
msg_time->dt[2] = (uint8_t)(msg_time->dt64>>16 &0xFF);
msg_time->dt[3] = (uint8_t)(msg_time->dt64>>24 &0xFF);
msg_time->dt[4] = (uint8_t)(msg_time->dt64>>32 &0xFF);
