My project now is going to use TGA3042-SM. This IC has a lot of Vg and Vd pins.
My question is Can I use only 1 power source for all Vg pins and 1 power source for all Vd pins? Im using ACT41000 for bias sequence and only has 1 source for Vg and 1 source for Vd.
Yes you can tie all the Vg pins together, and all the Vd pins together. This is how all the characterization testing on the TGA3042-SM has been done. Don’t connect the bias lines very close to the MMIC pins, or you can cause bias instability. You need some isolation and decoupling between the bias pins. You can refer to the TGA3042-SM eval board layout.
And one more thing, why they only mentioned in datasheet about top side and bottom side? Why don’t they mention that user can connect top and bottom side for convenience or better performance.
Page 15 of the TGA3042-SM datasheet has a note (2) that you can use either the top or bottom side of the MMIC for biasing. Biasing from one side makes layout easier. For a low power MMIC like this then single side vs double side biasing probably doesn’t impact performance too much. All plots and specs in the datasheet were taken with top and bottom side biasing.
