Tags positioning while not moving
I’m using MDEK1001 development kit receiving positioning data from serial port (USB) from a listener. Everything is working well, but I want to get the position of the tag/s while it is enabled and not moving, maybe at a much lower rate to safe battery life.
Is it possible to get a tag position if the tag is not moving?
Yes, this is possible. The tag update rate can be adjusted to a lower rate when it is stationary.
This can be configured via the Android App among other methods. Please consult the documentations.
Cheers,
Ken
Hi Ken
Thank you.
Izak
Hello Izak
Did you manage to implement that project on raspberry [pi>
Hi Kivule
Yes I did, but with gateways and mqtt server
Thank you very much Engineer, can you help me with the codes please and little explanation to expand my knowledge. I text my number through your inbox
