Hi all, would like to check how I can get the tag positioning accuracy values from my DRTLS system? Thank you
Hi @sadoctopus
in the location data is a QF value = quality factor the max 1 and the worst is 0. But it is an output form the location engine mixed with some other stuff so no exact meaning of this value. For example when you have only three anchors then it returns the same value all the time…
Im not sure if you should take look at ti, but it could help you.
Cheers
JK
