Hello, I put manually anchors positions and I can see them in the map. However, the tag does not positioning and always appears NaN (does not appears in the map).
Best regards.
Best regards.
Hi @laura.ece
NaN means that it cannot calculate its position. There are a few reasons for it:
Could you post the output of “les” shell command? Just few lines.
Cheers
JK
Also with the command “lec” it doesn´t answer with de position (POS), just with the distance to the anchors. How can I fix it?
Hi @laura.ece
sorry for the late reply. I think that your anchors are not well positioned or the location engine is disabled in the TN. Could you post the si output from the TN? But I think that the anchors positions are not correct.
Cheers
JK
