Using 3 anchors and 1 tag, I obtained the estimated position of the tag as the output - “est[-0.94, 0.37, -1.34, 89]”
What does the negative value of the coordinates infer?
How to infer the negative value practically in the field??
Hi guy,
The coordinates are relative to the [0, 0, 0] you are defining, the origin of coordinates you are using when configuring the anchors coordinates.
It is a classical cartesian coordinate system and coordinates can be negative relatively to the origin.
Hope it helps,
Regards
