I confirmed that dwt_probe() calls our platform-specific spiread() implementation and I also probed SPI lines to see that DM3000 returns correct CHIP_ID which is 0xDECA0302.
The second problem is that you specify the address of the end of the __dwt_driver_end symbol.
Second problem is that say if we reach the final N driver struct, the dwt_probe() will keep iterate and that obviously would end to an error.
I do not understand what “driver struct” here. Do you mean “struct dwt_driver_s dw3000_driver”?
Should I need to implement such structure in the code? I do not see any reference implementation for that structure in DWM3000EVB_Release_v1.2.zip file that I downloaded on Qorvo website.
Can you explain more about driver struct and how to support it in new MCU platform?
Best regards,
Ben
