Hello everyone! This is my first time working with UWB, and I wanted to ask where can I find sample codes for sending and receiving packets. I’m pretty new in this, but I can’t find the right resourses to start right.
Note: I have already installed SEGGER embedded studio, and I have the Qorvo SDK.
Thank you!
I’ve downloaded the SDK package before, and obtained Qorvo One. However, the Qorvo One App is not detecting my boards, and when I download the code on the devices, I am not really sure how to display the output, even though the documentation mentions the CLI.
CLI is for Command line interface. With this build you can type command via a serial interface to launch a fira application, change uwb configuration, go in continuous frame mode,etc …
However, when using Qorvo one you’ll need the UCI build.
For the CLI, the issue has been resolved. I was using Linux, but the software used to connect to the serial port was for Windows. I’m sure that there is some other compatible software/ method to do this using Linux.
Thank you for your help. I will try to use the UCI build now.
Is it possible to have both UCI and CLI builds on one device, or do they overwrite each other?
