Hi! I’m working on a uwb project and need some advice.
For the past few months, I’ve been using an ESP32 - Wroom 32. Currently, we’re switching to a nucleo f439ZI with a DWS1000 module due to the advantages it presents in terms of power, debugging, etc.
The goal of my project is to handle multiple rangings from different tags simultaneously in a “master” anchor.
I’ve seen that the DWS1000 is recommended to perform simple 1-on-1 readings (at least, this is what I found here: Evaluation Kit Selection Guide - Qorvo).
So my first question is: Has anyone used this combination to read distances with multiple devices? Is it a valid option?
Also, I’m a bit stuck with handling the migration of the code / starting to use some new libraries.
I’ve been developing a personal variation of the DW1000 thotro library: GitHub - thotro/arduino-dw1000: A library that offers functionality to use Decawave's DW1000 chips/modules with Arduino.
Has anyone used this library to work on this shield? Does it work?.
