I can’t get ss_twr_init to build in SES. I tried following general directions on Nordic Semiconductor’s website for importing Keil projects without any success. Does anyone have suggestions for successfully building ss_twr_init using SES and MDEK?
Hi Cormac,
What build error do you have ? The project should build with segger embedded, have you downloaded the required library and did you check if the source files path are aligned with the path the project file ?
Thank you,
Regards
It was a missing library as you mentioned. Thanks!
I can’t seem to get it working again and have checked all the libraries multiple times as well as started from scratch. Any recommendations? It is not finding the output files. I was able to manually create the .o output files, but not the .elf files. These keep getting deleted when I try to build.
Side Note: I think a video of starting from scratch in SES through building a project would be very helpful for new Decawave users like myself.
