I am using DWM1001 module. I have a linux machine. Is it possible to download mentioned softwares on that machine rather than using the Virtual Box image?
Hanish
Hi Hanish,
Yes it is theoretically possible, you will have to replicate the work environment of the virtual machine to your native linux machine.
We currently don’t provide a guide to port the environment, so there is a bit of exploration required to find what must exactly be done.
Hi Yves,
Does the DWM1001 module only works on Linux environment or can I use Windows OS by installing all the required softwares?
Also, Is there any code base where I can get reference examples for DWM1001?
Hanish
Hi Hanish,
I assume you are using the DWM1001-dev.
The firmware you will find on the virtual box allow to customized the PANS software. We are basically providing a fully working development work environment so we limit the support regarding installation of third part software.
If you work on windows, we have some simple examples on git:
Please note those example are very basic, and much more simple than “PANS”, but they will allow you to flash a DWM1001 device and start playing with it.
Regards
Thanks for your help Yves
