Hello All,
I am using an Arduino to get its position from a DWM1001 tag via UART connection. The tag’s position is sent to the arduino, which is then sent to my PC via serial connection (USB cable).
I was wondering if there was some way to set the anchors’ positions using shell mode in the tag itself? I know you can set the anchor’s position using the “aps” command in shell mode as well as setting the position via the Bluetooth using the DRTLS program. However I was hoping to set the anchors’ positions using the tag. Has anyone tried this?
