hi ,
has anyone used header pin with raspberry pi as a gataway with a node bridge unit to see result of a network on the web manager.
if so could u display some pictures of the web manager in real time with the network.
also could u display a screenshot of the uart mode using minicom.
and finally explain the steps to establish this (meaning seeing results of the network in the rtls web manager)
The DWM1001 + RPI is something like this:
The webmanager looks like this:
If you go through the below document, there is detailed description of how this works.
DWM1001_DWM1001-DEV_MDEK1001_Sources_and_Docs_v9\DWM1001\Product_and_Design_DocumentsDWM1001_Gateway_Quick_Deployment_Guide.pdf
The above package is downloadable from https://www.decawave.com/dwm1001-dw10001-dev-and-mdek1001-documents-source-code-android-application-firmware-image
