I really, really want to switch from LTspice to QSPICE. However the lack of explicit documentation is making it very difficult.
There is a rumor how importing 3rd party libraries is now made seamless, but I do not feel that way.
Assume that I am given BJT model not as .model but as .subckt with arbitrary pin order. In LTspice, I copied the *.asy file for bjt, and with arbitrary pin order of that one particular symbol I assigned to this symbol that subckt as ‘X’ together with linked path to the subckt. Later I could seamlessly use that symbol as is.
I cannot find a way how to do the similar in QSPICE. Every tutorial I found was only on importing .model which is indeed trivial. Other tutorials on imporiting opamps as .subckt always ended with drawing an arbitrary triangle. Am I really supposed to redraw symbol every time I import model/subckt? How can I organize my own library of symbols so that i can reuse them. I am willing to redraw all my exisitng schematics I have in LTspice, but I am definitely not willing to draw every symbol every time as this would lead to incosistencies and totally useless work I guess. Call me lazy, but there must be a library of standard symbols like Zener, Schottky, BJT, OpAmp such that I can seamlessly assign my subckt/model to them. Could you please navigate me how to do it?
In LTspice I always had for large project copy of lib folder containg cmp/sym/sub with my customized parts. This was part of search paths so I could easily work with it and could also be easy to share with anyone. How is this solved in QSPICE?
