…the above feature, gently described by @KSKelvin (many thanks!), automatically executes operating points calculation updating voltage & current info in the schematic.
It should be very useful to have the possibility to enable/disable “display probes” that show the voltage/current labels within the schematic continuously reporting the effects of the new selected value at component level to the operating point.
What a feature! I have never noticed it.
I would like to support @ToposKy’s suggestion. I very liked the LTspice’s schematic placeable Data labels. They can be placed related to node and it showed the node voltage. It not only solves the above related demand (you can place them to the nodes what you are interested in) but if they were detachable from node like in LTspice, the can be used as general computational labels. They can show not only voltages but current, power or any quantity what you can translate into mathematical formula. Very valuable extension to the op analysis’ result evaluation and I miss them from QSPICE.
@WinterMime thanks a lot for your support ! …
In the meantime, you may find similar features within the Microcap software. It “recently” was released as freeware since it is no longer updated and supported by the development team.
I really hope that similar features, to be considered as true milestones in the world of electronic simulation, can be inherited by a very promising tool such as QSPICE!
