Hi I have following setup for QM33120 evaluation kit
I have used CLI version and reading the data through serial port.
PAVRG have been set to 2 .
I am receiving following readings
I have following querry
- what is the convention of PDOA and PAOA (which side is positive and negative) ?
- Why there is difference between PDOA and PAOA readings are they are two methods of calculation of AOA or just a transform ? PAOA offset is 0 in my case
- Why is there so much fluctuation in readings even though the device is close apart and NLOS is aprox 0 ?
- Any performance parameter that needs to be tuned to get a better/ accurate readings from the device.?
Thanks for all your help and support.
