Question about BLE Operation in DW3_QM33_SDK_1.0.2 DWM3001CDK UCI Example
We are currently reviewing the DWM3001CDK UCI example from DW3_QM33_SDK_1.0.2 for our project.
We would like to integrate ble_app_uart from the ble_peripheral example in DW3_QM33_SDK_1.0.2 so that both UCI and BLE can function simultaneously on the DWM3001CDK.
Could you provide guidelines on how to modify the DWM3001CDK UCI example in DW3_QM33_SDK_1.0.2 to achieve this functionality?
Alternatively, is there an SDK available that already supports both UCI and BLE running concurrently?
Thank you in advance!
Hey shprak
How you got the UCI+BLE working?
If yes can you please share the information how you did it
Thank you
I am working on the same.. you have to add all the BLE support to the QM33 SDK.
technically it can be done, as the QANI SDK for 3001CDK board has BLE support.
the Nordic SDK is quite a challenge here.. (at least for me)
Yes, it’s too complicated, with too many configurations and those pre-compiled .a library files. I tried several approaches. My base was the UCI project, and I attempted to add the BLE part from the QANI project into it.
I’m working in VS Code, and I modified both sdk_config.h and CMakeLists.txt. Eventually, it compiled and built successfully. But as soon as I uncommented the BLE task, I flashed it — and it didn’t work.
So maybe we can share knowledge on this. Another option would be to add the UCI task into the QANI project instead.
I already built an Android app that performs ranging with the UCI project, but without ble so I have to hard code the address every single time for every session which is not useful, also, the problem is that UCI is not compatible with iOS. iOS requires the QANI project for Apple Nearby interaction.
That’s why if we manage to integrate the UCI task into QANI, I could achieve ranging on both iOS and Android.
Also, because of pre compiled library I can’t use the QANI project for android to do ranging , all the configuration is classified :cold_face:.
I am adding ble to the QM33 sdk supporting the UCI command set.
Because I want to be separated from Apple cause they broke nearby after iPhone 13.
Estimote had a library for android uwb navigation with their qorvo based beacons
And I ported my app to android successfully
Ok,I added The BLE into it, it is compiled and built, but the ble task cause crash.
Do you know, the Estimote bacon can support the Android and IOS as well? I need a hardware which can support both phones
Yes, updating the firmware is a challenge. I am looking for hireable skills to move us forward without much luck.
My code is built and returns all success, but doesn’t actually advertise. nrfConnect cannot find it.
I was able to do alternating ranging with android OR iOS,to the estimote beacons, but not both at the same time. As the two use different channels so it causes toggling and lost contacts.
My mobile app is written in ionic, so I have one source code base w different ‘plugins’ to map to the hardware apis which are close, but not exactly the same
Hi Rexxdad dis yuo ever get this to work ?
i have a custom design for BLE on UCI.
app talks to one board, called the controller, controller talks to other boards, called controlee(s)
so all the UWB ranging is outsourced to the controller/controlee boards.
communication from app to controller is now just BLE.. ,
with ranging status on ble notify back to app
uses the TWR command string to configure the sessions.
could do one->many, if I had enough devices to test with..
the new code and data doesn’t fit on the DWM3001CDK, Nordic 52833 memory just too small.
so my boards are the Murata Type2AB. (uses the Nordic 52840)
in the meantime, I have created another solution for Android ranging with the Qorvo boards.
I have since used Cursor AI dev tool to port my Ionic apps to React Native, and add Android support.
I used the cline visual studio AI assist to get the firmware running..
spent WAY too much time testing with the boards aimed away from each other..
software/firmware worked perfectly, reported timeout all the time. oops
used the Segger Ozone Source debugger
