QSPICE simulation of LTSPICE netlist runs but nothing appears in output window
Hi, 2Torr.
I’m unsure exactly how you’re trying to run this from the QSpice GUI. Please upload the schematic.
You’re a new user so see this post: Qspice Forum - New User to Basic User (File Upload) - QSPICE - Qorvo Tech Forum
Edit: If you want to run a netlist directly, enter the following in a command prompt window:
"c:\program files\qspice\qspice64.exe" test2.cir
Where test2.cir is the netlist. If successful, this will generate test2.qraw which you can double-click in File Explorer to open in the Waveform viewer. If not successful, you’ll get error messages that may help identify the problem.
–robert
