QSchView -- A Schematic Viewer/Printer & SVG Export Tool for QSpice
QSchView is an open-source QSpice schematic viewer, printer, and SVG export tool. Like QSpice, you can open & view QSpice schematics. In addition, you can:
  • View a schematic without installing QSpice.
  • Preview and print entire schematics or selected pages.
  • “Print to PDF” without using the Microsoft PDF printer.
  • Export to SVG for use in Inkscape or other SVG editors.
  • Do any of the above in batch using the command-line features.
The SVG export feature deserves some explanation: In the past, I’ve recommended using the open-source ClawPDF tool to create SVG files. However, the ClawPDF SVG printer has no concept of objects or layers; every element is drawn on the printer in a single layer.
The QSchView SVG export groups drawing elements into individual objects – a transistor symbol is a single object instead of a bunch of lines, circles, etc. Element types are grouped on layers – Symbols, wires, background, etc., are on separate layers. This should make editing with Inkscape or other SVG editors much more convenient.
Did I mention Linux? In theory, this tool can be ported to Linux. It would, of course, be only a viewer and printer but if anyone thinks this would be useful, let me know.
The current, early beta version of the project is here.
If you try it and find problems, please let me know.
–robert
QSchView code and binaries have been updated to fix a symbol rendering error.
I’ve updated the QSchView code and binaries again. Prior versions incorrectly produced SVG paths (i.e., line segments) for curved objects. While generally unnoticeable at normal zoom levels, the program should now produce properly smoothed Bezier curves at all zoom levels in Inkscape, PDFs, etc. The SVG files should also be somewhat smaller.
Of course, please let me know if you encounter issues.
