QPL9504 matching networks on evaluation board QPL9504EVB-01
I tested QPL9504 on evaluation board, and it seems that it does not perform as expected. I checked suggested value for 5-6 GHz, and calculated my own matching network, and components values are very different. Maybe, because of different matching network topology. You will find copy of my calculation below:
To match output of the device at 5.GHz, I used an L-section matching network consisting of a 1.37 pF shunt capacitor and a 1.02 nH series inductor (or alternatively, a 0.71 nH shunt inductor and a 6.30 pF series capacitor) - for low-pass (or high pass) configuration.
I also noticed that you suggested to use 18 nH 0603 inductor L1 on evaluation board, optimized for 5-6 GHz. It is Coilcraft p/n 0603CS-18NXJRU. However, datasheet for it specifies min self-resonance frequency 3.3 GHz. This means that on 5–6 GHz this inductor may have capacitive character, and it will not work as an inductor anymore. Did I miss something?
As about an input matching network on the evaluation board, optimized for 5-6 GHz - did it optimized for the minimum loss or for the minimum NF?
As your questions on matching the QPL9504 are quite involved it would be best to talk directly to your local Qorvo applications engineer. Please contact appsupport@qorvo.com stating your company name and location. Thanks.
