Hi @SIKS , this should be possible. The reason why you are not seeing any data might be related to antenna delay calibration (or an absence thereof). I would recommend to click Configure for each device and import a calibration file as a reference. You can use this file as a reference: SDK\Tools\uwb-qorvo-tools\scripts\device\load_cal\calib_files\QM33120WDK1\jolie_omni_non_aoa.json.
This should get you started and then you can fine tune the antenna delay. Please make to put the boards at least a few feet apart in this case as without a calibration antenna delay, it will show 0 cm at close distances.
