QM33120WDK1 how to run the examples in API folder from J3
Hi good people!
I’m new to embedded systems and have been playing with QM33120WDK1 for a while.
So you know the daughterboards in this kit have two microUSB ports J2 and J3. I’ve been always been using J2 for debugging my code which is modified from the example codes in the Drivers/API folder. Now I’m wondering, if I want to use J3 to test my code (so the cables are not right behind the antennas), what should I do?
Any help will be appreciated!
BC0023
