in the datasheet of QM33120 it seems that it can trsnmit power of -32.3dBm/MHz.
I know this power is outside the regulation limit, but we need this setting for lab setup
can you share how do we activate this max power setting?
Hi @danoz ,
Could you give us more details on which FW you use in this experiment?
it is test FW v0.6, from Murata module Type2AB
Could you try to use the latest SDK on our website?
Click here to download
This SDK has a calibration key called tx_power_index. If you set the TX power index to 0x00000000, you will get the maximum available power.
Kind regards,
Emre
