I have a custom board with DWM1001 fitted and connected to my host micro controller via UART.
There are a couple of questions I have:
Can you set the node as Anchor with X, Y and Z location and ID like you do when you set up the DWM1001 dev kit (it uses Bluetooth app but I want to do same thing using the UART)
Do the DWM1001 modules get supplied pre-loaded with same API firmware as the dev-kit and have “les” command etc?
Thanks in advance.
