I’m having issues using a model created using the THS4551.lib file available from TI. I receive these errors in the console:
Error in line .model _w1•x_w1•x3 iswitch roff•x_w1•x3=10e6 ron•x_w1•x3=1 ioff•x_w1•x3=5e-6 ion•x_w1•x3=7e-6
Unknown model type "ISWITCH" - ignored.
Error in line .model _w2•x_w2•x3 iswitch roff•x_w2•x3=10e6 ron•x_w2•x3=1 ioff•x_w2•x3=5e-6 ion•x_w2•x3=7e-6
Didn't find a model for "_W1•X_W1•X3" -- defaults assumed.
Didn't find a model for "_W2•X_W2•X3" -- defaults assumed.
Fatal error: Either both of Ion and Ioff or It and Ih must be specified for switch model W
Does anyone have any idea how to resolve these errors? Thanks!
Here is the contents of the .lib file:
* THS4551 - Rev. A
* Created by Sean Cashin; 06-10-2021
* Created with Green-Williams-Lis Current Sense Amp Macro-model Architecture
* Copyright 2020 by Texas Instruments Corporation
* MACRO-MODEL SIMULATED PARAMETERS:
* AC PARAMETERS
* CLOSED-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zout vs. Freq.)
* CLOSED-LOOP GAIN AND PHASE VS. FREQUENCY WITH RL, CL EFFECTS (Acl vs. Freq.)
* COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR vs. Freq.)
* POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR vs. Freq.)
* INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en vs. Freq.)
* DC PARAMETERS
* INPUT COMMON-MODE VOLTAGE RANGE (Vcm)
* GAIN ERROR (Eg)
* INPUT BIAS CURRENT VS. INPUT COMMON-MODE VOLTAGE (Ib vs. Vcm)
* INPUT OFFSET VOLTAGE VS. TEMPERATURE (Vos vs. Temp)
* OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vout vs. Iout)
* SHORT-CIRCUIT OUTPUT CURRENT (Isc)
* QUIESCENT CURRENT (Iq)
* TRANSIENT PARAMETERS
* SLEW RATE (SR)
* SETTLING TIME VS. CAPACITIVE LOAD (ts)
* OVERLOAD RECOVERY TIME (tor)
.subckt THS4551 IN+ IN- OUT+ OUT- VOCM VCC VEE
.MODEL R_NOISE RES (T_ABS=27)
.MODEL R_NOISELESS RES (T_ABS=-273.15)
C_C1 MID CLAMP 2.08E-9
C_C10 MID N1220320 1E-15
C_C11 N1220432 MID 1E-15
C_C1A N781369 N703229 45.47E-12
C_C1A10 N783783 N706294 1.768E-10
C_C1A11 N798514 N798524 208E-9
C_C1A13 MID VOCM 7E-12
C_C1A14 MID AOLVOCM 20E-9
C_C1A9 N782670 N709248 3.979E-11
C_C1B MID N798870 15.92E-15
C_C1B1 MID N1022352 15.92E-15
C_C1C N798590 N798598 60E-15
C_C33 N406634 0 1E-15
C_C34 N317950 0 1
C_C35 N406794 0 1E-15
C_C36 N1063588 N757831 99.47E-15
C_C37 INN MID 1E-15
C_C5 AOL_3 MID 800E-15
C_C7 INP MID 1E-15
C_C8 MID N1116251 1E-15
C_C9 MID N1117233 1E-15
C_C_DIFF ESDN ESDP 1.2E-12
C_C_VCLP VCLP MID 1E-12
C_C_VIMON MID VIMON 1E-12
C_C_VOUT_S MID VOUT_S 1E-12
E_E2 N91498 MID AOL_3 MID 1
E_E3 N112292 MID OUT+ OUT- 1
E_E6 MID 0 N317950 0 1
E_E7 N799654 MID ZO+ OUT- 1
E_E8 N1220502 MID VEE_CLP VCC_CLP 1
E_E9 N1220118 MID VCC_CLP VEE_CLP 1
G_G1 N781369 MID ESDP MID 0.01
G_G12 N79669 MID CLAMP MID -1E-3
G_G2 N10570 N10561 N703229 MID -1E-3
G_G36 VCC_B 0 VCC 0 -1
G_G37 VEE_B 0 VEE 0 -1
G_G5 N798514 MID AOL_3 N799654 -700
G_G58 N782670 MID VCC_B MID 7.906E-3
G_G59 N783783 MID VEE_B MID 3.514E-2
G_G6 N25816 N11984 N709248 N706294 -1E-3
G_G60 N694641 MID N757831 MID -1
G_G61 N798534 MID N798524 MID -1
G_G68 AOLVOCM MID N1242451 VOUT_CM -1
G_G69 ZO+ MID AOLVOCM MID -1E-3
G_G70 OUT- MID AOLVOCM MID -1E-3
G_G71 N1022298 MID N798544 MID -1
G_G72 N1063588 MID N79669 MID -1
G_G8 VCC_CLP MID N1116251 MID -1E-3
G_G9 VEE_CLP MID N1117233 MID -1E-3
G_GB2 N798590 MID N1022308 MID -100
G_GB3 AOLZO+ AOLZO- N798598 MID -142.9
I_I_B MID N06458 DC 1E-6
I_I_OS MID ESDN DC 990E-9
I_I_Q VCC VEE DC 1.37E-3
L_L1 N694641 AOL_3 350E-9
R_R1 ESDP IN+ R_NOISELESS 10E-3
R_R10 ESDN N1151745 R_NOISELESS 1E-3
R_R107 VCC_B 0 R_NOISELESS 1
R_R108 N317950 0 R_NOISELESS 1E12
R_R109 VEE_B 0 R_NOISELESS 1
R_R110 VCC_B N406634 R_NOISELESS 1E-3
R_R111 N406634 N317950 R_NOISELESS 1E6
R_R112 N317950 N406794 R_NOISELESS 1E6
R_R113 N406794 VEE_B R_NOISELESS 1E-3
R_R141 N781369 MID R_NOISELESS 1
R_R142 N782670 MID R_NOISELESS 1
R_R143 N783783 MID R_NOISELESS 1
R_R145 N694641 MID R_NOISELESS 1
R_R146 AOL_3 MID R_NOISELESS 800
R_R147 MID N798514 R_NOISELESS 1
R_R148 MID N798534 R_NOISELESS 1
R_R168 VCC VOCM R_NOISE 300E3
R_R169 VOCM VEE R_NOISE 300E3
R_R184 MID ZO+ R_NOISELESS 1E3
R_R185 MID OUT- R_NOISELESS 1E3
R_R186 OUT- AOLZO- R_NOISELESS 350E3
R_R187 ZO+ AOLZO+ R_NOISELESS 350E3
R_R188 ZO+ OUT- R_NOISELESS 70E3
R_R190 MID N1022298 R_NOISELESS 1
R_R195 N1063588 MID R_NOISELESS 1
R_R196 N1063588 N757831 R_NOISELESS 10E3
R_R197 N757831 MID R_NOISELESS 11.43E3
R_R1A N781369 N703229 R_NOISELESS 10E3
R_R1A10 N782670 N709248 R_NOISELESS 10E3
R_R1A11 N783783 N706294 R_NOISELESS 10E3
R_R1A12 N798524 N798514 R_NOISELESS 10E3
R_R1B N798870 N798544 R_NOISELESS 10E3
R_R1B1 N1022352 N1022308 R_NOISELESS 10E3
R_R1C N798598 N798590 R_NOISELESS 10E3
R_R2 ESDN IN- R_NOISELESS 10E-3
R_R200 AOLZO- VOUT_CM R_NOISELESS 0.5
R_R201 N1151603 MID R_NOISELESS 1E9
R_R202 INN N1151717 R_NOISELESS 1E-3
R_R203 MID N1151717 R_NOISELESS 1
R_R204 MID N1151839 R_NOISELESS 1E9
R_R205 MID CLAMP R_NOISELESS 1E6
R_R21 N11984 N25816 R_NOISELESS 1E3
R_R25 MID N28602 R_NOISELESS 1E9
R_R26 N30136 MID R_NOISELESS 1E9
R_R27 MID N30913 R_NOISELESS 1
R_R28 INP N30913 R_NOISELESS 1E-3
R_R29 N1116229 VCC_B R_NOISELESS 1E3
R_R2A N703229 MID R_NOISELESS 1.75
R_R2A10 N709248 MID R_NOISELESS 4
R_R2A11 N706294 MID R_NOISELESS 0.9
R_R2A12 MID N798524 R_NOISELESS 85.73
R_R2B N798544 N798534 R_NOISELESS 1.351E6
R_R2B1 N1022308 N1022298 R_NOISELESS 50E3
R_R3 N1174153 N1174757 R_NOISELESS 1E5
R_R30 N1116251 N1116229 R_NOISELESS 1E-3
R_R31 VCC_CLP MID R_NOISELESS 1E3
R_R32 N1117217 VEE_B R_NOISELESS 1E3
R_R33 N1117233 N1117217 R_NOISELESS 1E-3
R_R34 VEE_CLP MID R_NOISELESS 1E3
R_R35 MID N1220118 R_NOISELESS 1E9
R_R36 N1220292 MID R_NOISELESS 1
R_R37 N1220320 N1220292 R_NOISELESS 1E-3
R_R38 N1220432 N1220418 R_NOISELESS 1E-3
R_R39 MID N1220418 R_NOISELESS 1
R_R4 MID N798590 R_NOISELESS 1
R_R40 MID N1220502 R_NOISELESS 1E9
R_R5 VOUT_CM AOLZO+ R_NOISELESS 0.5
R_R6 MID N798598 R_NOISELESS 101
R_R60 MID AOLNET R_NOISELESS 1E6
R_R62 MID N79669 R_NOISELESS 1E3
R_R8 N10561 N10570 R_NOISELESS 1E3
R_R81 MID N110431 R_NOISELESS 1E9
R_R83 MID N112292 R_NOISELESS 1E9
R_R9 N10570 N11984 R_NOISELESS 1E-3
R_R_VCLP N91498 VCLP R_NOISELESS 100
R_R_VIMON VIMON N110431 R_NOISELESS 100
R_R_VOUT_S VOUT_S N112292 R_NOISELESS 100
V_CMVOS N1242451 N1252473 0.2E-3
V_VCM_MAX N30136 VCC_B -1.1
V_VCM_MAX1 N1151603 VCC_B -1.1
V_VCM_MIN N28602 VEE_B -0.2
V_VCM_MIN1 N1151839 VEE_B -0.2
X_AOL_1_THS4551 INP INN MID AOLNET AOL_1_THS4551
X_AOL_2 AOLNET MID MID CLAMP AOL_2_THS4551
X_CLAWN MID VIMON VEE_B N1117217 CLAWN_THS4551
X_CLAWP VIMON MID N1116229 VCC_B CLAWP_THS4551
X_CLAW_AMP N1220118 N1220502 VOUT_S MID N1220292 N1220418 CLAMP_AMP_LO_THS4551
X_CLAW_SRC N1220320 N1220432 CLAMP MID CLAW_SRC_THS4551
X_ESD_OUT OUT+ VCC VEE ESD_OUT_THS4551
X_ESD_OUT1 OUT- VCC VEE ESD_OUT_THS4551
X_H3 OUT+ ZO+ N110431 MID 08_OP_AMP_COMPLETE_H3_THS4551
X_IQ_N MID VIMON MID VEE IQ_SRC_THS4551
X_IQ_P VIMON MID VCC MID IQ_SRC_THS4551
X_I_NN ESDN MID FEMT_THS4551
X_I_NP N06458 MID FEMT_THS4551
X_S10 VEE_CLP ZO+ ZO+ MID 08_OP_AMP_COMPLETE_S10_THS4551
X_S11 OUT- VCC_CLP OUT- MID 08_OP_AMP_COMPLETE_S11_THS4551
X_S12 VEE_CLP OUT- OUT- MID 08_OP_AMP_COMPLETE_S12_THS4551
X_S13 AOLVOCM MID AOLVOCM MID 08_OP_AMP_COMPLETE_S13_THS4551
X_S14 MID AOLVOCM MID AOLVOCM 08_OP_AMP_COMPLETE_S14_THS4551
X_S9 ZO+ VCC_CLP ZO+ MID 08_OP_AMP_COMPLETE_S9_THS4551
X_U1 ESDP N06458 VNSE_THS4551
X_U2 VOCM N1252473 VNSE_THS4551
X_VCM_CLAMP N25816 MID N30913 MID N30136 N28602 VCM_CLAMP_THS4551
X_VCM_CLAMP1 N1151745 MID N1151717 MID N1151603 N1151839 VCM_CLAMP_THS4551
X_VOS_DRIFT N749288 N06458 VOS_DRIFT_THS4551
X_VOS_VS_VCM N10561 N749288 VCC VEE VOS_VS_VCM_THS4551
X_W1 N1174153 ESDN ESDP ESDN 08_OP_AMP_COMPLETE_W1_THS4551
X_W2 N1174757 ESDP ESDP ESDN 08_OP_AMP_COMPLETE_W2_THS4551
.ENDS THS4551
.SUBCKT 08_OP_AMP_COMPLETE_H3_THS4551 1 2 3 4
H_H3 3 4 VH_H3 -1E3
VH_H3 1 2 0V
.ENDS 08_OP_AMP_COMPLETE_H3_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_S10_THS4551 1 2 3 4
S_S10 3 4 1 2 _S10
RS_S10 1 2 1G
.MODEL _S10 VSWITCH ROFF=1E6 RON=1 VOFF=-0.1 VON=0.1
.ENDS 08_OP_AMP_COMPLETE_S10_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_S11_THS4551 1 2 3 4
S_S11 3 4 1 2 _S11
RS_S11 1 2 1G
.MODEL _S11 VSWITCH ROFF=1E6 RON=1 VOFF=-0.1 VON=0.1
.ENDS 08_OP_AMP_COMPLETE_S11_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_S12_THS4551 1 2 3 4
S_S12 3 4 1 2 _S12
RS_S12 1 2 1G
.MODEL _S12 VSWITCH ROFF=1E6 RON=1 VOFF=-0.1 VON=0.1
.ENDS 08_OP_AMP_COMPLETE_S12_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_S13_THS4551 1 2 3 4
S_S13 3 4 1 2 _S13
RS_S13 1 2 1G
.MODEL _S13 VSWITCH ROFF=2E3 RON=1 VOFF=3.5 VON=4
.ENDS 08_OP_AMP_COMPLETE_S13_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_S14_THS4551 1 2 3 4
S_S14 3 4 1 2 _S14
RS_S14 1 2 1G
.MODEL _S14 VSWITCH ROFF=2E3 RON=1 VOFF=3.5 VON=4
.ENDS 08_OP_AMP_COMPLETE_S14_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_S9_THS4551 1 2 3 4
S_S9 3 4 1 2 _S9
RS_S9 1 2 1G
.MODEL _S9 VSWITCH ROFF=1E6 RON=1 VOFF=-0.1 VON=0.1
.ENDS 08_OP_AMP_COMPLETE_S9_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_W1_THS4551 1 2 3 4
W_W1 3 4 VW_W1 _W1
VW_W1 1 2 0V
.MODEL _W1 ISWITCH ROFF=10E6 RON=1 IOFF=5E-6 ION=7E-6
.ENDS 08_OP_AMP_COMPLETE_W1_THS4551
.SUBCKT 08_OP_AMP_COMPLETE_W2_THS4551 1 2 3 4
W_W2 3 4 VW_W2 _W2
VW_W2 1 2 0V
.MODEL _W2 ISWITCH ROFF=10E6 RON=1 IOFF=5E-6 ION=7E-6
.ENDS 08_OP_AMP_COMPLETE_W2_THS4551
.SUBCKT AOL_1_THS4551 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-3
.PARAM IPOS = .5
.PARAM INEG = -.5
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)}
.ENDS AOL_1_THS4551
.SUBCKT AOL_2_THS4551 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 3.3E-3
.PARAM IPOS = 0.87
.PARAM INEG = -0.87
.ENDS AOL_2_THS4551
.SUBCKT CLAMP_AMP_LO_THS4551 VC+ VC- VIN COM VO+ VO-
.PARAM G=1
GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)}
GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)}
.ENDS CLAMP_AMP_LO_THS4551
.SUBCKT CLAWN_THS4551 VC+ VC- IOUT+ IOUT-
G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} =
+(-42.9, 1.17E-04)
+(-2.39, 9.06E-05)
+(0, 9E-5)
+(2.39, 9.06E-05)
+(42.9, 1.17E-04)
.ENDS CLAWN_THS4551
.SUBCKT CLAWP_THS4551 VC+ VC- IOUT+ IOUT-
+(-66.0, 5.00E-03)
+(-65.0, 1.50E-03)
+(-55.0, 1.25E-03)
+(-45.0, 1.00E-03)
+(-34.8, 7.43E-04)
+(-30.7, 6.57E-04)
+(-25.4, 4.68E-04)
+(-21.0, 3.99E-04)
+(-5.87, 1.51E-04)
+(-4.77, 1.13E-04)
+(-4.01, 1.02E-04)
+(-3.42, 1.08E-04)
+(-3.00, 1.02E-04)
+(0, 1E-04)
+(3.00, 1.02E-04)
+(3.42, 1.08E-04)
+(4.01, 1.02E-04)
+(4.77, 1.13E-04)
+(5.87, 1.51E-04)
+(21.0, 3.99E-04)
+(25.4, 4.68E-04)
+(30.7, 6.57E-04)
+(34.8, 7.43E-04)
+(45.0, 1.00E-03)
+(55.0, 1.25E-03)
+(65.0, 1.50E-03)
+(66.0, 5.00E-03)
.ENDS CLAWP_THS4551
.SUBCKT CLAW_SRC_THS4551 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 40
.PARAM IPOS = 20
.PARAM INEG = -20
.ENDS CLAW_SRC_THS4551
.SUBCKT ESD_OUT_THS4551 OUT VCC VEE
.MODEL ESD_SW VSWITCH(RON=50 ROFF=1E12 VON=500E-3 VOFF=450E-3)
S1 VCC OUT OUT VCC ESD_SW
S2 OUT VEE VEE OUT ESD_SW
.ENDS ESD_OUT_THS4551
.SUBCKT FEMT_THS4551 1 2
.PARAM FLWF=10
.PARAM NLFF=12E3
.PARAM NVRF=100
.PARAM GLFF={PWR(FLWF,0.25)*NLFF/1164}
.PARAM RNVF={1.184*PWR(NVRF,2)}
.MODEL DVNF D KF={PWR(FLWF,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVNF
D2 8 0 DVNF
E1 3 6 7 8 {GLFF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNVF}
R5 5 0 {RNVF}
R6 3 4 1E9
R7 4 0 1E9
G1 1 2 3 4 1E-6
.ENDS FEMT_THS4551
.SUBCKT IQ_SRC_THS4551 VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-3
G1 IOUT+ IOUT- VALUE={IF( (V(VC+,VC-)<=0),0,GAIN*V(VC+,VC-) )}
.ENDS IQ_SRC_THS4551
.SUBCKT VCM_CLAMP_THS4551 VIN+ VIN- IOUT- IOUT+ VP+ VP-
.PARAM GAIN = 1
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))}
.ENDS VCM_CLAMP_THS4551
.SUBCKT VNSE_THS4551 1 2
.PARAM FLW=10
.PARAM NLF=11
.PARAM NVR=3.33
.PARAM GLF={PWR(FLW,0.25)*NLF/1164}
.PARAM RNV={1.184*PWR(NVR,2)}
.MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
.ENDS VNSE_THS4551
.SUBCKT VOS_DRIFT_THS4551 VOS+ VOS-
.PARAM DC = 34.2E-6
.PARAM POL = 1
.PARAM DRIFT = 0.46E-6
E1 VOS+ VOS- VALUE={DC+POL*DRIFT*(TEMP-27)}
.ENDS VOS_DRIFT_THS4551
.SUBCKT VOS_VS_VCM_THS4551 V+ V- REF+ REF-
E1 V+ 1 TABLE {(V(REF+, V-))} =
+(0.35, 450E-6)
+(0.4, 435E-6)
+(0.55, 275E-6)
+(0.65, 150E-6)
+(0.75, 75E-6)
+(0.85, 25E-6)
+(1, 0)
V1 1 V- 0
.ENDS VOS_VS_VCM_THS4551
