Power Switch on the DWM1001-DEV
Hello, I’m using a DWM1001-DEV board connected to a battery through the JST connector. I want to put a power switch to switch off the board when I’m not using it without the need to disconnect the battery. Does anyone know how I can get this?
Thanks in advance!
Hi @jdlh
you just need to place some toggle switch on the battery cable (Toggle Switches(electronic toggle switches) | Electronic components. Distributor, online shop – Transfer Multisort Elektronik).
Cheers
JK
