The reason for the approach is my frustration of the many options that I have to respond to while manually drawing the schematic. With the arriaval of AI and ChatGPT ( among others) there must be a way. Here is the steps:
have a drawing of the simple circuit (see attachment)
Hi. It true that learning new things are a great goal.
I’m not sure what you are asking with your question in the forum. It appears you are suggesting a future improvement of QSpice? AI generation of schematics?
Note: I’ve created a simple schematic (attached) from your drawing to included. Effectively it won’t achieve your goal because the bridge rectifier you inserted is “upside-down”. The Bridge “+” is connected to the ‘-’ node and the Bridge “-” is connected to the “+” node.
I’ve included a second circuit on the schematic with the zeners and the polarized Cap flipped. This gives you the 12V (pseudo-regulated) circuit you intended.
I am delighted. Your response was much more than I expected. I will split your response in two parts:
The proposed approach can be understood as a request for future addition, but that was not my intention. I was hoping that someone or some company has developed such conversion. The technology of Interpreting a graph has come a long way now (not as good as interpreting voice to text)…
What is funny is I tried using Google Gimini and the result was disaster; simply because the topic (The Spice world) is almost exclusive to the very elite field of simulation. It has a lingo of its own.
As I mentioned in my post, the QSpice offers a lot of justifiable options that confuse the beginner…
I am an old timer (IT field) and this “language” can be compared to the basic assembly language that kicked off the present collection of programming languages. I can keep going on this topic but this is not the place for it.
2. your schema that you kindly did for me ( I will test it and I hope you will be able to handle hold me to get it done).
It is a simple circuit and you can safely correct the errors because it is COMMON CIRCUIT.
